| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76804 04/25/2007 10:51 PM | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | hi everyone! a couple quick questions reguarding guages for the 54 54 chevy truck, first off can i resoldier the water temp lineto the temp guage? second can i use an alternator and hook up to the DC guage... thanks for your help jeff  | | |
#76805 04/25/2007 11:15 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jeff,
Your temperature gauge is a hollow tube...a capillary tube full of ether. For all intensive purposes you cannot repair it. It has to be professionally repaired or replaced.
If you are asking if you can run a alternator and still use the ammeter, the answer is yes. The alternator BATT wire can connect to the BATT wire that was on the voltage regulator and this will run the alternator output through the ammeter and show charge. Hope I got this right.
Stuart | | |
