3 members (TUTS 59, greenie-reddy, Youngin' Tut 59), 56 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
hi everyone!
a couple quick questions reguarding guages for the 54 54 chevy truck, first off can i resoldier the water temp lineto the temp guage?
second can i use an alternator and hook up to the DC guage...
thanks for your help
jeff wink
Jeff,
Your temperature gauge is a hollow tube...a capillary tube full of ether. For all intensive purposes you cannot repair it. It has to be professionally repaired or replaced.
If you are asking if you can run a alternator and still use the ammeter, the answer is yes. The alternator BATT wire can connect to the BATT wire that was on the voltage regulator and this will run the alternator output through the ammeter and show charge. Hope I got this right.
Stuart
