hello got a 53 pickup here in swedem...a newer 270 gmc six is inside but the broblems is the brakes..or the hoses actually right rear tires has its own brake hose...a short one with a hole bolt is that org ?? and if so..were to find did look on the lmc page but could figure out what to order? inputs please regards stig m sweden
Hy pontiacfarmer, welcome, are you sure this hose is just going to the right rear wheel, or is it feeding the whole rear axle? If it is just a hose to the right rear, then it is not stock, some pictures would help a lot.
Hose generally refers to rubber. A line is steel. Steel lines are generally made by hand at home or in a shop. The black flexible hoses that we call rubber are purchased from a supplier.
Hy pontiacfarmer, I have never seen anything like that, every truck I've ever seen has a steel line from the tee out to the wheel cylinder. I'd say someone put that in there somewhere along the way, is the wheel cylinder port a standard 1/4" inverted flare?
hmmm if you guys never seen anything like..what do you think I have seen..........then need to take it to inspection before I remowe that hose..it wont pass and if I remowe it before inspection..then it might take WEEEKS to get a hose done grrrr or a org pipe? s
