| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I was in the process of installing the new bushings into the rear leaf springs (1946 Chev 1/2T) and found that one eye had been worn to the point that the bushing fell right through. Is there any fix for this, short of replacing the leaf? Can I find a replacement leaf with out buying an entire spring (8 leaves), and where?
Bob
BobS46
| | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | A spring shop will make just the main leaf if that is all you need. Ter
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I did order a new leaf. It is the long leaf on the left rear. Eaton seemed to think that I should replace the same leaf on both sides or it would make a very noticible difference in the overall suspension. Does ant one on the forum have a feel for this? Was Eaton primarily concerned about any liability if I was disatisfied? It is only one new leaf in a stack of 8, and the truck is not intended to ever carry a load. Eaton also felt that the one new leaf could cause onr of the others to crack.
BobS46
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I would replace the other side without question as they suggest. The truck will not be level if you just do one side. Don | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | it can make a difference - listen to the pros, their only concern is your satisfaction, they have no 'liability' for your work ... go cheap and walk home  Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had my spring guy tighten up the eye and install the bushing. He has machines to do that. I said to him after, "so I guess you heated it up to bend it". he said no, that would ruin the spring. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Absolutely replace both main leaves, as they cannot possibly match the years of wear on one leaf! And everything should be level.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks to all who replied. I kind of had that stuck in thye back of my mind, just hoped that there was a way to avoid the added expense. And I already had the bushings pressed into the other leaf - another lessoned learned.
Bob
BobS46
