7 members (MRMEROTH11, TUTS 59, Barney1951, Gray_Ghost, Wickedbass, JW51, walter74),
96
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I've read alot here about converting to an alternator, but still confused about what year or style(1 wire or 3 wire)I should buy. It's to replace my 12V generator on a 261 in a '50 3100 1/2T with no added options like AC or stereo. Pretty basic, so I'm thinking 60-70 amp style is enough. And I'm using a 3/8" belt, but can go to half inch with proper pulley on the alternator.Any suggestions? Thanks.
Drew
| | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Hi Drew, Here is some reading I did when I had the same questions. I hope this helps. Dale OneVSThreeWire 10SIor12SI
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Very informative. Answers many of my questions. Saving it all. Thanks to you both.
Drew
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | DrewP 1 wire vs. 3 wire is explained well by this guy at MAD Electrical. He's saved my bacon a couple of time s on projects I've had and is a wealth of knowledge on properly wiring and modifying electrical systems. Great tutorials at his site, too. http://www.madelectrical.com/mike | | |
