8 members (Gray_Ghost, Biermann, Hugh63c10, SmalltownTRKGuy, Phak1, Buckeye998, Gdads51, dt235sd), 138 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
#767578 08/01/2011 9:36 PM
hello
got a 53 pickup here in swedem...a newer 270 gmc six is inside but the broblems is the brakes..or the hoses actually
right rear tires has its own brake hose...a short one with a hole bolt
is that org ??
and if so..were to find
did look on the lmc page but could figure out what to order?
inputs please
regards stig m sweden
3B Offline
Hy pontiacfarmer, welcome, are you sure this hose is just going to the right rear wheel, or is it feeding the whole rear axle? If it is just a hose to the right rear, then it is not stock, some pictures would help a lot.
i took hoses off each wheel of my 53 3/4 ton
1963 c10
Is a "hose" a steel line or a rubber hose? The normal setup is a steel line from each rear backing plate to a brass tee near the centre of the axle.
1951 1 Ton Completed
Hose generally refers to rubber. A line is steel. Steel lines are generally made by hand at home or in a shop. The black flexible hoses that we call rubber are purchased from a supplier.
I was asking Pontiacfarmer the question. I am fairly clear on what a hose is, thanks.
3B Offline
Hy pontiacfarmer, I have never seen anything like that, every truck I've ever seen has a steel line from the tee out to the wheel cylinder. I'd say someone put that in there somewhere along the way, is the wheel cylinder port a standard 1/4" inverted flare?
donk know how to add photos so il do like this at the moment
s
hmmm
if you guys never seen anything like..what do you think I have seen..........then
need to take it to inspection before I remowe that hose..it wont pass and if I remowe it before inspection..then it might take WEEEKS to get a hose done
grrrr
or a org pipe?
s
What you want eventually is steel line from the tee to each rear wheel cylinder.
ok
the problem is what size on the fittings..one end against the t is usable but against the wheelcylinder......?
regards stig
...pic...
...pic...
...pic...
...pic...
above pics shows 3100 1/2 truck.
ok
looks what I need is a new pipe..wonder why they put in a hose 76454466 years ago ?
s
