4 members (Ponchogl, kades51, dt235sd, 1 invisible), 90 guests, and 1 robot.
Topics128,109
Posts1,056,569
Members48,448
I have a 1952 Chevy panel truck with a G80 axle that is 54.25 inches flange to flange. This is 4 inches less than the original axle. There is no room for the shocks which should be on the outside of the springs, because the wheels/tires overlap the axle by 2 inches. I was thinking of changing the wheels to 15x8 with 2.5 inch backspacing. This would be a -63mm offset. Or, should I use 2” wheel spacers?
The tires are P255/70R15.
Use the wheels with the 2.5 inch BS. Spacers can be hazardous if not instaled right.
I agree with that. If you must use spacers, get the kind that bolt on to the flange, and have a second set of studs for the wheels to mount to.
Bill Burmeister
Thank you for the advice. I ordered the offset rims.
