3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
My '41 GMC has a 1/4" steel line running through firewall into gauge cluster. The line is fed by a 1/8" oil line on the lower left side of engine block. The two lines are connected by a 6" piece of rubber line with different fittings on each end. I'm wondering if this is correct??
1960 GMC 1/2-ton Fleetside
"Donald"
More pix on Flickr
1941 GMC 1/2-Ton Short Box Stepside
"Wilburforce"
More pix on Flickr
1943? Chevrolet G7107
1946 Dodge COE 1-1/2 ton
1939 Allis Chalmers model "C"
Wonder no further... That is incorrect. Go to your local hotrod shop. They will probably have some fittings and some new copper line to run from the engine to the guage.
