| | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | so ive sandblasted all my brake parts and i dont know what paint i should use on them. i know that the drums require a special high heat paint but as for the rest of the parts i dont know.... the backing plate i will probably have powder coated
Any suggestions? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Someone told me to use black bar-b-cue paint for the drums. It's cheap and works well. I don't think it makes much difference on the rest of the parts, but if you wanted to be sure, maybe some rattle can engine paint. I used a zinc weld through product. It is like having it plated the paint sprays so thick. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | alright, ill give that a try thanks! | | |
