8 members (Gray_Ghost, Biermann, Hugh63c10, SmalltownTRKGuy, Phak1, Buckeye998, Gdads51, dt235sd),
138
Mod | | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 7 New Guy | | New Guy Joined: Nov 2005 Posts: 7 | hello got a 53 pickup here in swedem...a newer 270 gmc six is inside but the broblems is the brakes..or the hoses actually right rear tires has its own brake hose...a short one with a hole bolt is that org ?? and if so..were to find did look on the lmc page but could figure out what to order? inputs please regards stig m sweden | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pontiacfarmer, welcome, are you sure this hose is just going to the right rear wheel, or is it feeding the whole rear axle? If it is just a hose to the right rear, then it is not stock, some pictures would help a lot. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i took hoses off each wheel of my 53 3/4 ton
1963 c10 | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Is a "hose" a steel line or a rubber hose? The normal setup is a steel line from each rear backing plate to a brass tee near the centre of the axle. | | | | | Joined: Aug 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 38 | Hose generally refers to rubber. A line is steel. Steel lines are generally made by hand at home or in a shop. The black flexible hoses that we call rubber are purchased from a supplier. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I was asking Pontiacfarmer the question. I am fairly clear on what a hose is, thanks. | | | | | Joined: Nov 2005 Posts: 7 New Guy | | New Guy Joined: Nov 2005 Posts: 7 |
| | | | | Joined: Nov 2005 Posts: 7 New Guy | | New Guy Joined: Nov 2005 Posts: 7 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pontiacfarmer, I have never seen anything like that, every truck I've ever seen has a steel line from the tee out to the wheel cylinder. I'd say someone put that in there somewhere along the way, is the wheel cylinder port a standard 1/4" inverted flare? | | | | | Joined: Nov 2005 Posts: 7 New Guy | | New Guy Joined: Nov 2005 Posts: 7 | donk know how to add photos so il do like this at the moment s | | | | | Joined: Nov 2005 Posts: 7 New Guy | | New Guy Joined: Nov 2005 Posts: 7 | hmmm if you guys never seen anything like..what do you think I have seen..........then need to take it to inspection before I remowe that hose..it wont pass and if I remowe it before inspection..then it might take WEEEKS to get a hose done grrrr or a org pipe? s | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What you want eventually is steel line from the tee to each rear wheel cylinder. | | | | | Joined: Nov 2005 Posts: 7 New Guy | | New Guy Joined: Nov 2005 Posts: 7 | ok the problem is what size on the fittings..one end against the t is usable but against the wheelcylinder......? regards stig | | | | | Joined: Nov 2005 Posts: 7 New Guy | | New Guy Joined: Nov 2005 Posts: 7 | ok looks what I need is a new pipe..wonder why they put in a hose 76454466 years ago ? s | | |
