1 members (CuzzFuzz), 83 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#76764 04/25/2007 3:00 AM
I finally captured the seldom seen drilled 235 head bolt. I got lucky enough to get it on film and you can see it at, http://picasaweb.google.com/pre68bowtie/DrilledHeadBolt/photo#5055738197502233858
My Blog
Dave,
What a trophy. This allows lube to reach the center oiler, but whats with the hole. I thought it was merely the reduced shank that did the trick. Does the slotted head ID this as the 'special one'?
Stuart
The slot is just to identify it as special.
From 1938-62, only two head bolt part numbers are listed for 216, 235 and 261. Long and short except for a special drilled bolt, used when a 59-62 block is used with earlier top end* to reduce the oil flow to the rockers.
Note in parts book: Use with drilled bolt.
Plug # 3764579
Install in block oil port near right center head bolt.
(This plug blocks the original oil path and sends it through the drilled head bolt)
· The cylinder head did not change but the rockers did.
My Blog
