2 members (stlcardinalsguy, PAUL Berardi), 134 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#767269 07/31/2011 11:51 PM
Okay I have a ’46 2 ton with a 216 the system aperies to be the original 6 volt. The question came to me as I was posting my other electrical questions. How can I tell if the system is still 6v or has been half converted to 12v? Being in Alaska it is common to just patch things together and half the wires look like original 6v thick crumpling wires and some look like newer 12v wires. How do I tell if the generator, starter, all the electrical parts are 12v or 6v?
akguy34 #767277 08/01/2011 12:23 AM
Pull a headlight and get the part number off it.
Cletis #767280 08/01/2011 12:26 AM
no headlights frown
akguy34 #767290 08/01/2011 12:44 AM
check the color of the tags on the generator and starter [altho the 6V starter works on 12V], 12V are red, 6V blue
squeeze #767305 08/01/2011 1:30 AM
Okay thanks I'll look, I know the one that I canalized off a 235 doesn’t have a tag frown sometime in its life it was removed
akguy34 #767312 08/01/2011 1:43 AM
The voltage regulator usually has a voltage stamping on the base somewhere. If it's a Delco unit and it isn't marked with a voltage rating, post the part number and one of us with a parts manual or some service bulletins should be able to tell you which voltage rating it has. It's a little more difficult to identify a generator with the tag missing.
Ex Hall Monitor
Ex Hall Monitor
If there are any bulbs in it they will tell you, dash lights, tail light, park lights.
Tiny #769338 08/07/2011 4:27 PM
The fields in 6V units are wound with cloth tape,the 12v are dipped in a platic like substance.
