1 members (Uncles51),
105
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76725 04/24/2007 2:37 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I am redoing the brakes on the 61 Found On Road Dead truck I have. I have upgraded to really big 15" disk brakes and big dual piston calipers. The calipers have 1/4" line going to them, or they did when they ere in other trucks, so I will do the same.
I have a GM disk disk valve but am questioning if it will handle the flow, as one line going to it is 3/16, I have not checked, but lets assume I can change the tube nut for 1/4". Should I use a stock valve, or will an adjustable one be better? I will haul heavy loads and trailers with the truck, will the adjustable valve be a benefit?
Who makes the best adjustable valve, and who has the best price on it? I know Willwood sells one, who else?
Thanks, Grigg | | |
#76726 04/24/2007 3:10 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Hey, Grigg. I would definitely go with the adjustable proportioning valve. Road racers and roundy-round types use them a lot and there should be a number of hi-perf types available,
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
#76727 04/25/2007 9:56 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Wilwood makes one and you can get it from Summit...I just put one on my '63 | | |
#76728 04/26/2007 4:47 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Ordered one from Summit today, and the 2lb residual check valves also. | | |
