3 members (Bill Hanlon, Patina 54, Guitplayer), 88 guests, and 2 robots.
Topics128,035
Posts1,055,441
Members48,422
I am redoing the brakes on the 61 Found On Road Dead truck I have. I have upgraded to really big 15" disk brakes and big dual piston calipers. The calipers have 1/4" line going to them, or they did when they ere in other trucks, so I will do the same.
I have a GM disk disk valve but am questioning if it will handle the flow, as one line going to it is 3/16, I have not checked, but lets assume I can change the tube nut for 1/4".
Should I use a stock valve, or will an adjustable one be better?
I will haul heavy loads and trailers with the truck, will the adjustable valve be a benefit?
Who makes the best adjustable valve, and who has the best price on it? I know Willwood sells one, who else?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Hey, Grigg. I would definitely go with the adjustable proportioning valve. Road racers and roundy-round types use them a lot and there should be a number of hi-perf types available,
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
Wilwood makes one and you can get it from Summit...I just put one on my '63
Daily Driver 63 C-10 LWB Fleetside
Ordered one from Summit today, and the 2lb residual check valves also.
---All pictures---
