4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#766570 07/29/2011 2:56 AM
I just finished bolting on my glove box door.
I installed the lock as I remember it however the door won't catch and stay closed. Is there some kind of adjustment here?
Glove Box 1
Glove Box 2
Glove Box 3
~Jim
It doesn't look much different then the 46 set up. If your door is aligned correctly I would tweek the catch on the door. I did on mine and it worked. BTW the truck is looking great!
Jim, AFAIK the only 'adjustment' apart from the screws that secure the glove box door to the hinges is the metal catch on the actual door.
I assume the door is square and lined up OK.
I tweaked mine like Gman said with a pair of pliers and a cloth to avoid chipping the paint too much.
The nature of the catch will wear the paint on the latch over time anyway.
You want it to catch with enough pre-load on the rubber bumpers to avoid rattles.
More pix on Flickr.
If you can have someone close the door while you look up from underneath since your box is out. I did that and could see I needed to adjust the catch a bit and I also rotated the lock just a tiny bit.
OK here are two pics from the back as Brad suggested. In both pics the door is completely shut but the tab just barely touches the hook. Do I have the wrong lock set? It came from Classic Parts (Chevy Duty), #53-470.
Pic 1
Pic 2
~Jim
Jim, that does look weird..... headscratch
If you can bear with me,i'll have a look in mine, i'm headed out to the garage as soon as i've finished my morning cup of joe!
More pix on Flickr.
O.K Jim,so it's been a while since I last looked under the dash.
Your lock is correct.
Here's a couple of snaps I took this morning.
It looks like you need to tweak the glove box tab as mentioned earlier in the thread.
You can see mine took a fair bit of persuasion to fit.
(I know,I know..I also still need to finish the underside of the dash!)
Out of sight/out of mind eh! wink
I hope these help anyway.
Jock.
Pic # 1
Pic # 2
More pix on Flickr.
Thanks Jock,
Looks like there's going to be a whole lot of tweaking going on. I'm just (as always) afraid of too much tweaking resulting in a broken tab. ...must be a result of past excessive tweaking. lol
~Jim
Thanks Jock,
Sounds like a Jerry Lee Lewis song! grin
Good luck!
More pix on Flickr.
Finally got the Glove Box lock to hold the door. I had bought two locks from two different vendors hoping one would work, neither worked. I searched around and found the original lock. Then I measured the hook on the lock and compared it with the hooks on the new locks and discovered the new lock hooks were.04" shorter than the original. I put it on and the door shut and held. So much for Chinese junk.
~Jim
Moderated by  ndkid275, Phak1
