4 members (Phak1, IHPWR, 66flea, 1 invisible),
119
Mod | | | Forums66 Topics128,091 Posts1,056,445 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | Hi been looking for the actual vin numbers to match the bill of sale i have on this 59 truck i have problem is only number i can find is the tag on the door and its missing bout half the digits i need to even start to compare with the numbers on the bill of sale i assume he didn't just make up a number out of thin air the door tag only has about 6 or 7 numbers and the sale slip is more like 10-14 any help out there
Last edited by Woogeroo; 07/31/2011 4:22 AM. Reason: We have to guess: is it a Chevy or a GMC?
1937 1/2 ton
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the door vin tag is what would have been used at first registration - it should be in the form of 3A 59 K 104930 [11 characters], which would translate to 3100-1959-Kansas City plant, and the remaining numbers are the vehicle production sequence number or 'serial number' .... what's on a "bill of sale" might match that or it might be something the PO or state came up with .... the vin on a 59 will also be stamped on the driver side top frame web near the steering box, less the first 2 characters
an engine number would be even fewer characters, about 6
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Daniel Bland, go up to Tech Tips, and open up deciphering your VIN and see if the numbers on your paperwork have anything in common with the information there. | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | ones i have on the bill of sale are 3b 59 s127--- with the blanks being three more numbers but from what your saying thats a 59 vin number thanks  told me what i needed to know was just worried i might have been on the frame which now sports a camero sub lol and might have cut it off
1937 1/2 ton
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 3B = 3200 1/2T and S=St Louis - and yes, if it's been sub-framed you may well have cut it off, meaning short of the door tag matching that bill of sale, there's no proof it's the right truck  Bill | | |
