| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Hey Guys, Can anyone tell me whether the 4 front cross sills for the bed on a one ton 49 chevy are the same? I marked mine when I took the old truck apart, But after sand blasting and por-15 I can't see My marks.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | My frame had multiple holes not corresponding to the bolt holes for the wood beam support under my flat bed. I took measurements and marked the holes corresponding to each cross sill for the new truck bed. I could look up the numbers in my notebook if you like.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | if your talking about a flat bed then yes. on mine half of them face forward and the the rest face to the rear. what i do is make little punch marks where things are going to disappear after blasting. you have a puzzle now and in time you'll get it sorted out. when you do, then punch them so after they're painted it will go back together the correct way. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Mine is a step side pick up. Thanks for the responce.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | As far as we could tell, they are all the same. That is how we sell them. If there is a difference, I hope someone speaks up to explain.
Mar-Ktech | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | The only difference I have seen in a cross sill is when the truck came with an inside frame rail gas tank. There is an indentation for the tank on one of the cross sills. Those tanks were only found on Carry-alls and Panel trucks, to my knowledge. Yours should all be the same.
My first reply was about the location of the sill along the rail. My original bed came with 3 bolts on each side with no cross sills, instead of the six frame bolts and cross sills, as mentioned above, I found on my parts truck.
| | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Thank you very much guys! Good to be a bolter. Terry
