5 members (1955 1 Series, Southerntruck, tclederman, Rusted Nut, Peggy M), 38 guests, and 8 robots.
Topics128,010
Posts1,055,308
Members48,419
#766535 07/29/2011 1:32 AM
Took apart the front end of my 1950 Chevy 3100 today to get a little better under the hood. Removed the rotted valve cover to find a rusty old mess - complete with mouse nests & poop. I cleaned it out as best I could. Believe it or not, the spark plugs looked so nice under all that! I'm pretty sure there is a tool called a ___ bar to place into the end and see if the engine turns. Never put a battery in this and don't want to just see if it starts because I don't want to draw in all that crud from the fuel tank. Truck has been sitting for 30 years - until I brought the jalopy home a month ago. Can anyone tell me what kind of engine this is? I know its a straight 6 cyl., that's about all I know!! I'm new to this car game. Thanks!
Under the Hood Pics
216 engine
Slide 8
1 23 0
Date casting code: January 23rd 1950
Slides 9 & 10
3835517
Head casting code - 216 from 1950-1953
Looks like your basic 216 to me. If you can get the stamped numbers from the machined surface just behind the distributor, that can be decoded to tell exactly what it is, and were it originally came from, if the engine is not original to the truck.
Bill Burmeister
Here are locations of other casting codes and the engine serial number that Bill refers to.
Tim,
Didn't you mean to say...
3835517 is your head casting#
-Tom
1950 Chevy 3100 w/ 1956 235
I'm going to go out on a limb here and suggest that attempting to turn that thing over by hand will be a waste of time. I kind of want to see the head pulled just to see what sort of surprises are awaiting.
Sort of stock 1950 Chevrolet 3100
235 (The engine shread) (Engine assembly)- 4 speed - 12 bolt - stock front axle with power disc brakes
Yep, those valves, springs, and probably rocker arms are history. It wouldn't surprise me to find the pistons rusted tight to the cylinders, particularly if they're cast iron.
Wow, I haven't ever seen the sheet metal on a motor rusted through like that. I hope that some of the truck did a little better than the motor. Did it have a hood on it all those years?
1951 1 Ton Completed
Tom,
I corrected the word above.
