9 members (Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 52Carl, dt235sd, BC59, 2 invisible), 153 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
I have a 40 Chevy Panel Truck in need of two rear doors.
Can I 'expand' my search for 40 thur 46 Panels AND Suburbans??
Timmer
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
Timmer,
The panel door is the same from 39-46
http://chevy.oldcarmanualproject.com/1929_54chevyparts/16/753.HTM
PM sent.
Technically, not exactly the same,although they fit the same opening,
'39-'41 I believe have the lock mechanism in the handle itself and the '46 has the lock seperate (below) from the handle.
Great! Thanks for the info!
As long as they fit the opening, I can live
with the different locks.
