1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
#765649 07/26/2011 5:14 AM
After a number of years of sitting, waiting for me to get back to it, I've finally got the '50 running and driving down the road reliably (see truck and engine info below). Along with the old familiar engine, body, and general tin can noise there are a number of new rattles and ticks coming from the engine. One tick is pretty wicked when cold but the edge is gone when warm. Bad or sticky lifter? Another is a light knock when warm and only really when coming off the throttle and coasting in gear.
Also, the oil pressure drops to 10 or 15 psi when idling or shifting at low speeds. When I pulled the pan last there was a bunch of silver bearing material in the sump, not chunks just fine powder. More than I though there should be.
I want to end up with a hot rodded 6 when im done with this project so i have a 292 waiting for a rebuild but i dont want to spend the money yet if I can avoid it. Do the above symptoms spell impending doom for the 235 or can I milk it while gathering parts and getting the rest of the truck up to snuff?
I believe in doing things right the first time but i'm on a limited budget and if i did the engine now i would have a hot 292 with a stock 4 speed, crappy, wiring, and poor brakes on the rear end.
I knows it's difficult to diagnose engine problems online but just wanted to see what you all thought.
Sort of stock 1950 Chevrolet 3100
235 (The engine shread) (Engine assembly)- 4 speed - 12 bolt - stock front axle with power disc brakes
If you see bearing material in the oil then you need to rebuild. Before you ruin a crank. Time to find out for sure where that material is coming from.
I'd pull the oil pan and adjust the rod and main bearings. If you do find one that is gone you might be able to change out a rod and get by a bit longer. Back in the day it was a common maintenance to have to adjust the bearings.
I should have also mentioned it is a later high pressure 235 with insert bearings.
I don't think there should ever be bearing material in the sump. Something is going to pieces and those pieces are circulating throughout the motor. I think you have a ticking time bomb there and it would be best to take it apart.
1951 1 Ton Completed
