I looked in the tech tips for discs but don't see any ideas for removing existing front hubs from the drums. For those of you who used your stock hubs with discs - how did you remove the hubs from the drums? The splines on the hub bolts seem to be pressed in extremly tightly. Did you drill out the bolts? Thanks.
PS. Tried the shop manual but it makes no mention of removing or mounting hubs & drums.
