8 members (Wally / Montana, Mike Burns, HandyAndy, Patina 54, Cosmo, RoadsScholar, 2 invisible),
199
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Okay. So I to put new brakes all around and I start on the rear brakes. I have my new brake shoes and wheel cylinders and such in hand, and I find this... http://i1226.photobucket.com/albums/ee408/panacchai/wheelcylinder.jpgI hold up my new replacement cylinder from Jim Carters (great looking product by the way) and realize my cylinder is not the right size. I check my package... 1 Ton Wheel cylinder 14" drum - rear. However the cylinder on the truck is much larger. What size is this? Anyone even know or have seen this brake system before? http://i1226.photobucket.com/albums/ee408/panacchai/rearbrake-innerds.jpgDave
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Dave51Chev, according to the Jim Carter catalog your truck should use their part number ME773 1 3/8", what did you order? The picture of your brakes is of pre 1953 Huck brakes. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I ordered just a pair of those. 1 3/8" bore and everything. I haven't measured the others yet, but they seem to be something like a 1 1/2" bore size. They are about 30% larger in size to the wheel cylinders I received from them.
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Yes. The master cylinder was said to need replacing by the PO, which I had done by my mechanic. It was pretty well pitted. The brakes worked fine until the leak in the front cylinders showed up several weeks later, so I am replacing them all for consistency.
When I get a chance I'll try and get a picture of the new wheel cylinder next to the current. It's the new one that doesn't seem to mathc.
I'm a newbie to doing some of these repairs. Brakes is a whole new field for me. My mechanic encouraged me to try it myself. He doesn't want to take all the fun out of this for me.
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Don't get discouraged Dave, you're just having some bad luck getting the parts - once you have the right ones, its pretty straight forward.
The only difference between the rear cylinder and the front are the geared adjusters. You should check and see what you have on the front.
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Okay so I snapped a picture with what I got and what I have. The rear drum brake in this picture is of my 51-1Ton panel. I checked it as well. It even has "1 3/8" cast on the cylinder! http://i1226.photobucket.com/albums/ee408/panacchai/sidebyside.jpgThis is the REAR 1 TON Wheel Cylinder I ordered from Chevsofthe40s. Is it a matter of different adjustment gears? What have I got?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Dave51Chev, what part number did you order from Chevs of the 40s? I think you want 5450071, I think you might have 5300866. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | They (I have a pair) are part# 5450071. I think Bigtonka is onto something. I think they may have come with the adjustment gears for front wheels. But I need to investigate more. If spare time permits, I got to check the front cylinders. That's where the leak is, but I first wanted to tackle the park brake attachment on the rear and meanwhile change out the brake parts.
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I just browsed through Bigtonkas pics of his reassembled brakes [front and rear], and I think I may have answered my question.
Thanks guys for all your input!
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I just browsed through Bigtonkas pics of his reassembled brakes [front and rear], and I think I may have answered my question.
Thanks guys for all your input! Yes, those are most definitely fronts. You could use them in the front or swap the adjusters from your old ones (if their not too bad) I think you would also have to remove (or swap) that clip that steps the adjustments. What's your plan? | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I am planning on doing all four brakes. I guess now I will do the front first, then the back. I'll be ordering some rear cylinders from Jim Carter. I should call chevsofthe40s and let them know so they can adjust their description for other buyers.
Bigtonka, what did you do to clean up your parts? Blast then paint? I will be having my shoes relined, so I'll be reusing them. But I want it better looking if I'm getting newer parts where I can.
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Dave, My parts looked just like the condition of yours do now. (as you can see from my photos) I bought a handheld siphon sandblaster and blasted them in a home made blast cabinet. https://picasaweb.google.com/wmhatfield/MyUnnamedToyProject#5523865059123170306Before blasting though I had to clean off the grease and oil. My wheel seals were done and leaked diff fluid all through the brake assembly. This is a good time to replace them, you don't want to ruin new brake pads. I cleaned the "dangerous" way - using gas! *insert warnings and cautions* Then I blasted and painted all my parts with silver and black rust paint. This included all the springs etc... Of course nothing was painted when it was new - so this is purely to feed my obsession! Who's doing the shoe relining? | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Page Brake. They're a brake supplier out of Salt Lake City. They have a local store I can drop them off at. It's about $20 a shoe.
My uncle used to always use diesel fuel to clean with. It had less of an odor, but it still is flammable! Why not just use brake cleaner and a shop rag to remove the dirt and oil?
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Ya, I used brake cleaner as well - just the real built up parts I let soak in gas.
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Hey Bigtonka. Did you buy new shoes or have them relined? I am wondering if it's okay to blast and paint, then send them off for relining?
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Hi Dave,
I had the existing shoes relined. When I got them back, part of relining is cleaning and painting. So what you see in my photos is what the shop did. (to my surprise!)
This was the first time I've had this done, so I was pleasantly surprised. Ask Page Brake if the service includes that.
Mark | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I'm dropping them off today. I'll ask if that's include. If not, I'll request the service. It's worth it! My assembly won't be as nice as yours, but it'll look a lot nicer than it was.
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | More important is the function over looks! | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | i got my new wheel cylinders today! It's a match! As soon as the brakes shoe come back and are installed, I'll load up a few pictures.
FYI... for anyone who is considering having their brake shoes relined, it is general practice that the shoes are cleaned and painted to ensure the friction material has a good surface to bond to. If you can't find new shoes, this is a great alternative. Thanks to the guys at Page Brake in Salt Lake City for the info!
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Excellent - bet you can't wait to get them reassembled!
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Brakes are done! Newly relined shoes, new cylinders, fresh brake fluid. Went to start the truck to do a rolling test... the battery dies. It's on the charger. Might have to wait til tomorrow morning for that ride.
| | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | Great news! Congratulations on getting the big solo project done!
Now can someone tell me if the only difference between the fronts and rears are the adjusters? There is a $40+ price difference between the fronts and rears at NAPA, and I'm thinking I could just swap the adjusters from the old wheel cylinders over to a set of front ones?
Jeremy Cheap skate
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Great news! Congratulations on getting the big solo project done!
Jeremy Cheap skate are you talking w/c. if so the rears are larger cheap skate in playing with brakes is playing with others lives; yours doesn't count ron | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | are you talking w/c. if so the rears are larger cheap skate in playing with brakes is playing with others lives; yours doesn't count ron Wrong - the wheel cylinders on a 1 ton front and rear are the same size. Napa numbers. fronts UP4358, rears UP9325, they both have 1 3/8" bores, just different adjusters. If the adjusters are cleaned up they'll swap and work just fine. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | mine are bigger on the rear. of course mine is a little newer | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Jeremy, Unfortunately, the rear cylinders are actually "longer" than the front cylinders eventhough they have the same bore diameter (see my pic). The front is a 12" drum and the rear is a 14" drum; take that into consideration as well.
To be honest, the price difference for me was $20. $50 for front, $70 for rear. Fronts were purchased from Chevsfromthe40s and rears from Jim Carter Classic Truck Parts as mentioned above. Best deals I could find. Local Auto Parts Stores are going to list them more expensive, and they'll have to order them anyway. I recommend you order them online from the same place as me. Shipping was fast from both places.
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Really? I hate to be a source of miss information!
Now I have to check my old parts. I was told last year that they're the same less the adjusters. :P | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | why not hone them first and see what they look like. you might just be able to use a kit. ron | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | The cylinder length difference is nominal, like 1/8 or 1/4". It just means it'll hold more fluid. For the larger size drum, I guess you can use the rear adjusters and extend the adjusting screws. Oh yeah and that flap for the adjusters.
Padresag has a good suggestion. Hone the cylinder and see what you got. Sometimes a kit is all you need for a repair. Pitting is usually the culprit of a bad cylinder.
If you do swap a front cylinder to the rear, you may find that the brake line fitting looks different since the front uses a hose and the rear has a junction block with a banjo bolt.
| | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | Thanks for the input, I'll see what the fronts look like this week. I suspect the rears are pitted, the m/c certainly was. If the fronts won't interchange, I'm more likely to sleeve, hone and rebuild the rears rather than not buy locally. My NAPA is a nice family owned shop. They treat me well and will always give me a lower price than list. I'll support them for all the stuff they can get for me. I'll save the mail order shops for the stuff no one else has..
Jeremy | | |
