| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 29 New Guy | | New Guy Joined: Jan 2007 Posts: 29 | The altenator I used was from a 78 chevy van http://images2.snapfish.com/232323232%7Ffp53986%3Enu%3D32%3B4%3E7%3B6%3E862%3EWSNRCG%3D369568%3B792337nu0mrj
The bracket I built. The spacer bracket allowed me to move the rear mounting bracket back, I think this makes it stronger than the brackets I've seen commercially. http://images2.snapfish.com/232323232%7Ffp539%3B5%3Enu%3D32%3B4%3E7%3B6%3E862%3EWSNRCG%3D369569625%3B337nu0mrj
Test Fit in motor http://images2.snapfish.com/232323232%7Ffp53994%3Enu%3D32%3B4%3E7%3B6%3E862%3EWSNRCG%3D3695695976337nu0mrj
Test fit of altenator http://images2.snapfish.com/232323232%7Ffp53993%3Enu%3D32%3B4%3E7%3B6%3E862%3EWSNRCG%3D369568%3B783337nu0mrj
After I tweaked the spacer braket on the altenator the alignment was perfect!
Too Many Projects, not enough time
| | | | | Joined: Jan 2007 Posts: 29 New Guy | | New Guy Joined: Jan 2007 Posts: 29 | Other mods done
Used Pully off Generator, had to shave cooling fins slightly
Picked up a ballast resitor (for the coil)from local parts store (one listed for a 64 Impala)
12 volt battery
pulled all bulbs to find replacements (not done yet)
Disconnected fuel sender, will order resistor for it this week
Replaced 10ga wire (mine was pretty cracked)
Used the hook-up method were one wire from the plastic plug goes to post on back of ALT and other goes to a indictor light on dash
Fired up the truck, check the belt, doing great. Indicator light didn't go off, checked wire looks correct, checked voltages, looks like donor ALT was bad:( Have to get replacement.
| | | | | Joined: Jan 2007 Posts: 29 New Guy | | New Guy Joined: Jan 2007 Posts: 29 | oops guess I put it in the wrong place, all better now  also, are the pic links working ok for everyone? after I first posted this, first two didn't work so I edited them. After all the time and planning that went into the designing and building of this bracket I guess the $60 for the ones online isn't so bad. But I had the metal laying around, I own a mig welder, and I have the satifaction of doing it myself, which is of course "priceless" KSTT
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | First two links working for me. | | | | | Joined: Jan 2007 Posts: 29 New Guy | | New Guy Joined: Jan 2007 Posts: 29 |
