3 members (Wayne67vert, Otto Skorzeny, stlcardinalsguy), 66 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#765113 07/24/2011 3:49 PM
hi, all my lights were just working great put a new engine in & changed my rack & pinion but now no headlights? all others work? checked fuse panel they are good? is there another fuse on the switch i cant see?? what to do? please & thanks
sorry i forgot to say its a 1950 3100
Riding in the Passing Lane
Check the dimmer switch.That is generally where headlight problems are. It is in a horrible invironment.
1972 Chevy c10 Cheyenne Super
For me the problem is generally that I forget to hook the lights back into the harness after I re-attach the fender!
1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in.
Dear Nobadays,
double check the wire connections on the inner fender on both sides.
On the drivers side.. the wires from the light switch will terminate on the inner fender torwards the front at a multi-connector terminal ( can't remember the real name). Then a separate length of a wire bundle will attach to the terminal go across the radiator area to the passenger inner fender to another multi terminal. Wires go from the terminals to parking lights and headlights on both sides.
Make sure there is a good ground.
Good Luck
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
