Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Stovebolt48, SNOYL, Hugh63c10, Cletus1950, Barnfind49, Gib70, Otto Skorzeny, klhansen), 76 guests, and 5 robots.
Topics128,281
Posts1,058,460
Members48,490
Since its been too many years since I took the radiator off, I can't remember the order of bracket and pads (there are apparently two of them) and front cross member when re-assembling. I am guessing that the large head carriage bolt goes thru the radiator bracket since it has the square holes, with one or both of the rectangular rubber support pads between it and the cross member? Yes/No???? All help appreciated. I went to look at a 1941 1/2 ton GMC parts truck of a friend and everything about it and the radiator was different from mine. Ron
Opportunity is missed by most people because it is dressed in overalls
and looks like work. - Thomas Edison
1941 AL 3/4 ton 125-1/4 WB, bought by my Great Uncle Matt in 1942. Still in the family.
Ron, my 46 had 2 rubber pads between the crossmember and radiator frame.
Thanks, thats how I will go. I guess i was only wondering why two pads instead of one thicker one.
I also found out the replacement rubber is not as thick as the original, I messed around with some spare rubber pads I had laying around to create the same thickness so everything would line up correctly.
