3 members (Otto Skorzeny, dwreills, Peggy M), 56 guests, and 2 robots.
Topics128,035
Posts1,055,446
Members48,422
#764977 07/24/2011 12:06 AM
What kind of glue do I use to install the stock headliner with a 1/8 inch foam rubber backing? A couple of spray types have let go. The foam is sticking to the headliner well but is letting go from the foam to the metal roof. Thanks for any help.
Mike
you might not have much luck with foam against the hot/cold/hot/cold metal - could try really saturating it so the glue doesn't all just get wicked into the cells, but I'd use some Reflectix, the foil covered bubble pack stuff, in place of foam
squeeze #765006 07/24/2011 2:19 AM
Contact Cement?
GMC: Get More Cash...
1958 GMC
My Webshots photos
I didn't think they were glued to the roof. Anyway, I can't help with glue to the roof, but thought you might be interested in an alternative...
I went a different route - no glue and it's been on for a couple of years now with no problems at all.
Moderated by  ndkid275, Phak1
