6 members (1955 1 Series, Still At It, Bill Hanlon, klhansen, 42465967, 1 invisible), 117 guests, and 2 robots.
Topics128,159
Posts1,056,901
Members48,458
#76495 04/19/2007 3:12 PM
-db
Offline
- Offline
Hi,
I am looking to find the oil line on a 235 that runs from the oil filter housing to the oil pressure gauge T on the block.
Thanks.
#76496 04/19/2007 4:28 PM
The FLAPS I work at part-time makes hoses, I made one in hydraulic hose very similar to an oil filter hose on Sun, cost the man $12. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#76497 04/19/2007 4:55 PM
-db
Offline
- Offline
Ok, if that's all it cost then I may just have one made locally.
#76498 04/19/2007 5:30 PM
Mine are just standard steel tubing (like brake lines, only smaller in Diameter.
I don't think I have a picture handy, but I can take one tonight when I get home, if you like.
#76499 04/19/2007 9:30 PM
Wouldn't a 3/16 brake line double flaired do the trick?
~Jim
#76500 04/20/2007 12:53 AM
I used 1/4" double flare on mine.
Bill Burmeister
#76501 04/20/2007 1:38 AM
-db
Offline
- Offline
So a normal metal brake line will work?
#76502 04/20/2007 5:23 PM
-db,
Yes it will, very nicely actually. A brake line is designed for a working pressure many, many times what your engine oil pressure is. And, you can paint or plate it to your preference.
1949 "Heinz 57"
#76503 04/20/2007 6:23 PM
-db
Offline
- Offline
Thanks for the info. This means I can get it fixed on Sunday.
