4 members (sawdust54, G508, Peggy M, Uncles51), 86 guests, and 3 robots.
Topics128,028
Posts1,055,414
Members48,422
I have deciphered the casting numbers on my engine installed in my '50 to discover I have a 235 cast in 1959 (using lucky mold number 13). I can't find any info on the serial number on the distributor pad, F325JC703. The 703 looks hand stamped.
Any help would be appreciated.
Sort of stock 1950 Chevrolet 3100
235 (The engine shread) (Engine assembly)- 4 speed - 12 bolt - stock front axle with power disc brakes
back yard wrench turner
Try here to find year of casting number
http://www.inliners.org/casting/numbers.html
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
It looks like RingLeader is asking about an engine serial number?
Here are 1958 and 1959 engine serial number decodings:
http://chevy.oldcarmanualproject.com/chevyresto/58t074.htm
http://chevy.oldcarmanualproject.com/chevyresto/59tsn03.htm
F325JC703 does not contain year information.
F = Flint, MI
3 = March
5 = 25th
JC = 4000 series and 3100/3200/3600/3800 series with Heavy Duty clutch (RPO-227)
Look at the indices in those books for RPO numbers and features.
The 703 is where a sequence number should be, but those numbers usually had a minimum of 4 digits, starting at 1001.
Thanks tcelderman! Just the info I needed. Odd on the sequence number though, I went back and checked and it definitely says 703. Maybe someone wasn't paying attention that day in '59.
