0 members (),
89
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Ok.... well I think I am ready to try and fire Jessica's Truck this weekend. I was wondering if there was a standard jet setting the carb should be set to as a beginning point to make her run. I had the carb rebuilt at a local shop and I do not know where they set the jets so I have no Idea where they should be set either. Any help here would be greatly appreciated and I certainly ain't a motor guy. What else am I forgetting? Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | if you are refering to the idle mixture screws,turn them clock-wise gently til they stop,when back them out 1 1/2 to 2 turns for a starting point | | |
