6 members (Samantha, Cosmo, Otto Skorzeny, Brian Moore, Jims46, 1 invisible), 58 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#764755 07/23/2011 3:02 AM
V
V Offline
Ok.... well I think I am ready to try and fire Jessica's Truck this weekend. I was wondering if there was a standard jet setting the carb should be set to as a beginning point to make her run. I had the carb rebuilt at a local shop and I do not know where they set the jets so I have no Idea where they should be set either. Any help here would be greatly appreciated and I certainly ain't a motor guy. What else am I forgetting?
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
if you are refering to the idle mixture screws,turn them clock-wise gently til they stop,when back them out 1 1/2 to 2 turns for a starting point
