0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 14 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 14 | I am putting a Rochester B Carburetor on my 1953 Chevy with a 216 Engine. It doesn't currently have an insulator between the engine and the carb. Is that something that is necessary? Is that an item that can be purchased at a local auto parts store or does something like that have to be special ordered?
Thanks! Jesse | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its good to have it but you will need to change the linkage & studs if you do. One for the 216 will be harder to find but I think the specialty suppliers have it. If its been running without it I think I would try it without it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | That insulator should be standard equipment. Without it, you can get percolation in the fuel bowl on even a moderately hot day, and it will be hard to re-start after driving till fuel pump re-fills the bowl. May also leak all over manifolds, and be potential fire hazard. Jim Carter and others list them.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | Quick question and I think answer. I have a 54 3100 with a 62 235 c.i. engine. Last week I noticed that there was percolation in my glass fuel filter bowl. This was after a 20 mile trip with weather in the high 90's. Lots of coughing and missing for the last ten miles. Was hard to start after shutting down. After reading your post I checked, and low and behold, I don't have a insulator between my carb and manifold. Ordering one from J.C. this morning.
Disciple
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think that they all came with the insulator from the factory. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, the insulator was standard equipment, except maybe with updraft carbs(?), with a purpose, as posted above. There are two sizes, as posted above. Here are specific parts from Tim's helpful links: Jim Carter - earlier insulator plate Jim Carter - later insulator plate Classic Parts - smaller opening Classic Parts - larger opening Even though the shop manuals do not refer to gaskets, a gasket is usually needed between the carburetor and the insulator plate (with properly orientated slots in the gasket to match up with a vacuum port in the base of the carb). A gasket might not be need between the insulator and the intake manifold. You will most likely have to use longer carburetor mounting studs in the intake manifold.
Last edited by tclederman; 07/23/2011 2:55 AM. Reason: corrections made thanks to bowtietim
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Hey Tim,you got Jim carters links marked classic !!
Make sure you order the correct carburetor base gasket as well .
Tim!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good gasket reminder, Tim. Thanks for the correction. I fixed it (I hope).
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim,
Thanks for the second correction, Tim.
Maybe I have it correct now?
Home made beer and single malt Scotch has taken its toll (I am on vacation with relatives and friends in NC). I should know better (I'll try to resist making posts until I am sober and get home to NY).
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | LOL !!!!! Looks like the right links now. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
