3 members (JW51, Otto Skorzeny, 1 invisible),
112
Mod | | | Forums66 Topics128,269 Posts1,058,402 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 | My brother is building the bed for our Fallen Hero's Dream Ride project. Problem is, he's in San Diego and the truck is in Missouri. Is there a way to accurately determine where the mounting holes are drilled without having the truck and boards together? Does Mar-K instructions provide this information?
Dave www.fallenherosdreamride.orgall give some MY SON GAVE ALL The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216 In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Yes, Mar-K can provide a detailed instruction sheet. You should check out their website, under technical info.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Hi Dave,
Here is my ex-spurt (the drip under pressure kind) opinion. I milled my own wood out of yellow cedar, bought the stainless strips and bolt set from Mar-K, and marked the holes in place. The Mar-K instructions were fantastic and they were a great outfit to work with.
I would have been very uncomfortable drilling the holes without marking them in place. Here is the process I used for the install. The first step was to slide the edge boards under the angle strips to mark the bolt holes. The cross sills were attached next using measurements supplied by Mark-K. Middle boards get bolted through the gap left between the boards so no drilling here. And finally the bed to frame bolts and offset washer holes were traced from below removed and drilled. There were some measurements given here to use as a double check. | | |
