| | | Forums66 Topics128,163 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I'm rebuilding my Rochester B. I went to my local parts (Lordco- Canadian) store to get a rebuild kit and they said they needed the number off the carb. When I bought the BC rebuild kit they didn't need the number; so I'm not sure of the problem. Are they just the typical (go by the book, don't think) parts people or do I need the tag number. It's a Rochester B off of a '51 216. I want to put it on my 235, if that matters. Maybe someone can help me out. Thanks. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I'm not sure it will fit the 235. Seems like the bolt holes aren't the right distance. But it shouldn't be hard for them to find a kit for it. Unless they don't know how to look it up in a book. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there are a number of different "Rochester B's" and ones for different applications [including tractors] that have different internals, it's always best to have the tag number, but check here and take a guess which one you might have Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is only 2 kits listed for the model B. The parts guy should be able to get it from the application. They put extra parts in them so one kit can cover several variations. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | In the "for what its worth" category: we show 34 DIFFERENT kits for the Rochester type B carburetor.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
