5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#763571 07/18/2011 7:15 PM
I just purchased a 54 Chevy 3600 with a 235 straight 6 in it. I thought i was having fuel pump problems. After checking it out and finding nothing apparently wrong with it i put more fuel in the tank and it fired right up. I was wondering if anyone knew if it was just one of the limitations of the old mechanical fuel pumps that you need to keep a certain amount of fuel in the tank to help with the pressure or if it may be going out on me?
[Linked Image from i1188.photobucket.com]
The fuel pickup is not right against the bottom. If the truck has been sitting the bottom of the tank could be full of sediment maybe.
It looks like a fairly new tank and i just put a new fuel filter on it and the fuel coming out looks clean. My fuel gage doesn't work though so i'm sure that it just didn't have enough fuel in it. I just wanted to make sure. Thanks you for your help
