0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | mike, just went out and looked at my '40, which looks the same. The coiled part of the spring definitely sits on one side of the handle, and I think it is original. And it works fine! Good luck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | Mike, I took two pics of the handle on my '37. I believe it to be original. This one is from the passenger side. Never mind the broken glove box. This pic is from behind. You can see how it just sits inside the handle. It does move around a bit, but works well enough. Hope this helps. | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Thanks to all. Guess I'll just have to live with the the spring moving around. | | |
