| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | Is there some instruction sheet on repairing a speedometer for an 52 AD ? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 |
Ed
| | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | Can the speedometer needle be removed and replaced without taking apart the whole unit ? The odometer works fine. | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Yes it can, But you do need to take it out of the housing, once you have the chrome bezel and lens off you can take out the two screws that hod the unit in the housing and hold the small shaft just under the face with a pair of needle nose and lightly twist the hub loose and off taking care not to bend or twist and an angle to the shaft t(the shaft can be bent or broken easily). Mike | | |
