| | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | I’m trying to get some information on swapping out the stock 8 lug hub and brakes on the front end of my 51 3600 with a more modern 5 lug brake system. Not sure what would fit on the original spindle. It doesn’t have to be disc, but would be nice. I’ve seen there is a new disc brake conversion set-up out there, but don’t really want to spend the money on that. Any help would be great, thank you. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The problem with the 3600 trucks is that they have a larger king pin than the 3100's. The bad part is that pretty much all your aftermarket kits are for the 3100's. You may be able to get a machine shop to bore and bush the axles to use other spindles or if you can round up a 3100 axle and swap the whole works, you're in the ballpark. Then you would have a lot more options. | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | 51FarmTruck,the cheapest,and less expensive way,would go on parts wanted,and ask if anyone,has a half ton front axle for sale.I was fortunate enough that I had a half ton axle,at the time,I used the kit for spindles,I used the 1/2 ton axle,on my 3600,it bolts right up to the leaf springs. Thought I would share that with you,Good Luck,and Keep On Trucking!!
| | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | I'm going to go look at a 1/2 ton front end set up today after I get off work. If I remember right if I use the 1/2 ton axle/spindles then I can bolt up 49-54 Chevy car backing plate and brakes... Is that correct? Are there any cars that have a disc brake setup that would bolt up to the 1/2 ton spindle? | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | 51FarmTruck,the kit I used was spindles,rotors,and calipers,was sold to me by a friend of mine. He already had all the components,1/2 straight axle and all. There are kits available,might inquire here on the Forum. Cletis,is usually real helpful on here. My kit was a 79Camaro. You will need someone,to align the frontend,for you that are familiar with this type setup. Hope I have been of help to you. I can't remember some of the vendors on here that can help you out.Good Luck,Keep On Trucking! | | |
