BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,776 Posts1,039,259 Members48,100 | Most Online2,175 Jul 21st, 2025 | |
#76276 04/12/2007 8:30 PM | Joined: Jun 2003 Posts: 27 New Guy | New Guy Joined: Jun 2003 Posts: 27 | Have a '51 3100 series with a 235. I'm rebuilding the 3-speed tranny and in checking the clutch both the pressure plate and flywheel are heat checked. I want to have them turned or replaced but I can not get the flywheel off - any suggestions. This truck has been my daily driver up til a few days ago when I pulled the tranny. | | |
#76277 04/12/2007 8:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I supose you have removed the clutch & 6 bolts holding the flywheel on. Get 2 prybars & work it back & forth from behind. A little penatrant will help. Be careful. That thing is heavy & can come down fast. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#76278 04/12/2007 8:48 PM | Joined: Jan 2006 Posts: 586 Shop Shark | Shop Shark Joined: Jan 2006 Posts: 586 | Pull the bolts off,then put two back on a few turns to keep it from falling on your head.Spray some Kroil or WD-40 on the crankshaft end and hit the flywheel with a piece of wood (2x4).You can have the flywheel machined but not the pressure plate surface.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#76279 04/13/2007 2:35 AM | Joined: Aug 2001 Posts: 1,285 'Bolter | 'Bolter Joined: Aug 2001 Posts: 1,285 | I put carpet under truck, stayed clear and whacked it with a rubber mallet. Don't try to catch it when it falls. Just give it a soft place to land. | | |
#76280 04/14/2007 2:07 AM | Joined: Jun 2003 Posts: 27 New Guy | New Guy Joined: Jun 2003 Posts: 27 | Huge thanks to all of you who responded - it took the application of all of the suggestions to finally break free the flywheel! Had the flywheel and pressure plate resurfaced today and will be installing them tomorrow. The ring in the pressure plate was broken so had that re-rivited and the plate resurfaced - basically rebuilt - less than $70 which I thought was a VERY good price. | | |
#76281 05/03/2007 6:46 PM | Joined: Jan 2006 Posts: 586 Shop Shark | Shop Shark Joined: Jan 2006 Posts: 586 | I am shocked that you were able to find a shop that will take the time to resurface or rebuild a pressure plate.I thought those guys went the way of the Edsel.You can't beat that price too.
#76282 05/04/2007 9:02 AM | Joined: Apr 2005 Posts: 641 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 641 | take a big block of wood and hit it as hard as you can it will come loose works for stuck brake drums to | | |
