0 members (), 136 guests, and 3 robots.
Topics128,193
Posts1,057,259
Members48,466
#762644 07/15/2011 4:36 AM
I am switching out my Rochester BC back to the '51 Rochester B. Because I am going back to Manual choke and throttle, I believe I don't need the vac adv anymore. Is this true? If so, do I just disconnect the line from the vac adv to the choke and plug the hole?
The vacuum advance has nothing to do with the choke or throttle. It advances the timing at the distributor. It is necessary on a stock engine.
Yeah I'm dumb. I had this idea in my head (without looking) that my Rochester B didn't have a vacuum line.
Thanks for putting me back in line.
You most definitely need the vacuum advance hooked up.
You will no longer need the stove plate and heat tube that hooks to the BC carburetors choke.
Tim
1951 3100 Chevrolet
