2 members (Rusty Rod, porsche), 64 guests, and 3 robots.
Topics128,021
Posts1,055,357
Members48,420
#761539 07/11/2011 8:30 PM
I need to figure out how to make an inside the cab hood release for my '48. I'm sure someone here has done that before. any links or pics or ideas available? thanks.
I just took the hood release cable out of a 79 Buick and tied it into the original latch mechanism with a drilled hole. I also drilled a second hole for a return spring but it probably wasn't needed. My plan is to cut the portion of the old latch off below the holes but just haven't got around to it yet. I can shoot some pics this evening if needed.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
hey Vern, thanks, a pic would be awesome. I knew it would be something simple. I'll check back later. smile
"Something simple"....with should include convenient, reliable, and 100% functional. I traveled down this same road and discovered that the original latch assembly did not lend itself well to adapting an inside release. Secondly, with a solid chin pan you may find yourself weilding a sawzall when your cable rig malfunctions!!!!
Thankfully, my concerns for a remote release were for security reasons and someone on the bolt had already added a couple simple pieces to the stock latch assembly so that a padlock could be added. I trust s search for "hood lock" should turn up the pictures. If your concerns are for security you might consider this as a "simple" alternative.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Under the hood.
cable routing
in the cab.
You could obviously do a better job with the proper "Z" connection on the cable instead of just tie a knot like I did. I'll get around to fixing that some day. I made the bracket from 3/4" x 3/4" angle iron.
1953 Chevrolet 3600
Good Job Vern! thanks for the pics. Thanks Dave, too, I will also search for the lock idea. I remember I saw that awhile ago, but then forgot...:)
I used the cable and latch assembly from an old Taurus with good results.
Robert C.
I'm a Genius in the making.
1950 3600
Robert, you used a bunch of old taurus parts with good results smile
Gotta use what you got!!! grin
Robert C.
1950 3600
