0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | Hello all. I am getting ready to start the build of my 51 3600 and was trying to find a frame to put under it without having to mess with the stock one. I found that the wheelbase on mine is 125.25. I have seen guys talk about the S-10 frames, but even the long bed is almost 3 inches short, and I don't want to cut the running boards or the box. So I found that the 3rd gen of Chevy vans has a 125 inch wheelbase.
My question is; Has anyone used a van chassis under their AD? Would it even work?(width, couture...etc?) I am very much trying to go on the cheep. but also get something that is a bit newer so parts are more readily available.
Thanks, any help is greatly appreciated. Brian
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I'm not sure the third generation Chevy van even has a frame under it. The S-10 frame is telescopic, so it is adjustable if you wanted it shorter, but I don't know about longer.
I think there would be a lot more 'messing' if you went with a frame swap, than if you stayed with the stock frame.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | why not use the stock frame? it fits
| | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | You're right it does, however, I haven't been able to find much information on making changes to the 3/4 driveline and suspension. Mainly the front end. I really would like to get away from the 8 lug because there isn't a lot of options for wheel combinations. So if you have some suggestions on what i could do to get a 5 lug on it with more modern brakes (not a new disc conversion). I have a 9inch and a 700R4 already and still debating on the engine at the moment. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | What have you looked at so far? You've got tons of choices from MMII,corvette & several several clips to choose from. You might check with Scott Danforth here on the forum. He designed a corssmember for the A.D. I used a narrowed 79 half ton and a 70's camaro rear on my 3600.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
