1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 4 New Guy | | New Guy Joined: Jun 2011 Posts: 4 | I know it's a little new, but hoping you guys can help me out.
I just picked up this 1969 GMC 2500 series "custom camper" truck.
305 V6 engine, long bed, 8 lug 16" aluminum wheels, 4 on the floor, power steering, power brakes, under dash AC (works), new starter, alternator, new gas tank (1 of 3), a tad rusty, especially the drivers floor board and rocker, a little in the bed, but structurally sound and the body is solid.
Has new brakes all around, but does have a loud engine knock. Think it might be a spun bearing or ????. Drives fine, but due to the loud noise, I brought it home until I find a mechanic who is familiar with this engine. I'd like to pull the oil pan and inspect it, but the 1 foot cross member seems to be in the way. Thoughts?
What's it worth? (What are the 4 wheels alone worth? 8 Lug 16" aluminum)
I'm trying to decide whether to pay to have the bottom end of the engine rebuilt, rebuild the entire engine or ????
I'm not crazy about tossing a SBC 350 in it, as it will lose all of it's towing power.
This BEAST rides very nice and drives so easy, especially compared to my bare bones '58.
Any experts out there on this truck? Would love to know more about it. (HP, Torque, production, etc).
It does need a new windshield and seat covers, but the leather embossed door panels are SA-WEET!
Sorry, the system won't let me upload pics. I'll send them to photobucket and post a link.
I'm looking for parts suppliers....none of the truck websites I've looked at even list this engine??? (I've heard is 3/4ths of a common V8?)
Any help would be appreciated!
58stepside(at)gmail.com | | | | | Joined: Jun 2011 Posts: 4 New Guy | | New Guy Joined: Jun 2011 Posts: 4 | | | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | Cool truck, I have the same motor in my '66. I found alot of info on these motors at "The 6066 GMC Guy" website, all I know about parts suppliers is I got the rebuild kit at my local Carquest, and my friend and I rebuilt the motor. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Before you tear it down, try this: Dump a glass of water down the carburator while the engine is running. You could have a Carbon Knock. Dump it in slowly and rev it some so it doesn't stall.
My '66 305 V-6 was famous for building up carbon. A glass of water later and it was cured. Also had a 350 V-8 that had a carbon problem. Had to use the water trick on that engine a few times during the 7 years I had it on the road. There is no telling how many engines out there got thrown away because of a simple carbon knock.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Automatic transmission fluid also does a great job of cleaning it out and also freeing stuck valves. Apllied the same way as the water, rev it up and SLOWLY add the oil. It will also kill all the mosquitos in the neighborhood :-)
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | John,
The first time I ever tried it, we used half water and half trans fluid. It doesn't really mix well, but it did the job. It did create a great smoke show. I had to warn my neighbor first, lol.
But when I was sure it was just carbon, I then switched to just water.
I like the idea of it freeing stuck valves. I'll have to remember that one.
| | | | | Joined: Jun 2011 Posts: 4 New Guy | | New Guy Joined: Jun 2011 Posts: 4 | Thanks, I'm willing to give just about anything a try! I have heard of tranny fluid before...that seems similar to using a commercial product like Seafoam, but I haven't heard of using water. I thought that would cause hydrolock and crack a piston? | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Drizzle the water in SLOWLY with the engine at a fast idle, 2,000 RPM or so. The water breaks up into a mist as it hits the carburetor venturi.
Before you try the water trick, try to isolate the knock to a particular cylinder by disconnecting spark plug wires one at a time. A cracked piston skirt or a loose wrist pin bushing will quiet down with the ignition disabled, and a rod bearing knock will sometimes change to a double-bump sound without a firing load on the piston. If you can change the noise by disabling a cylinder, better do a teardown to find the source of the problem.
The GMC V-6's are TRUCK engines, not similar to Chevy V-8's at all. They have a 60-degree angle between the cylinder banks, and fire on a 120-degree rotation sequence just like an inline six. They are low-speed, high torque engines, and they burn gas like it's going out of style. Don't even think about getting good fuel economy, but they really excel at pulling heavy loads for a long time. Jerry
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Jerry,
Believe it or not, with a fresh super tune I was getting 15 1/2 MPG Hi-way with my 305 V-6 that I had in a 1/2 Ton Pick-up.
Now I also drove a 478 V-6. Not bad for what the truck was, but I believe that one was getting an all around 7 to 9.
Also drove a 637 V-8. We figured that one around 5 to 7.
| | | | | Joined: May 2009 Posts: 8 New Guy | | New Guy Joined: May 2009 Posts: 8 | I just bought a 1962 GMC 4x4 3/4 ton with the 305 v-6, I have no current use for the motor,but the previous owner loved it. I had one back in the early 80's when I was in high school, my buddy's and I put that truck through more abuse than Geraldo's nose, and it never even missed a stroke.
Bogiebuddy | | | | | Joined: Jun 2011 Posts: 4 New Guy | | New Guy Joined: Jun 2011 Posts: 4 | I just bought a 1962 GMC 4x4 3/4 ton with the 305 v-6, I have no current use for the motor,but the previous owner loved it. I had one back in the early 80's when I was in high school, my buddy's and I put that truck through more abuse than Geraldo's nose, and it never even missed a stroke.
Bogiebuddy Too bad it's across the country...shipping would be difficult to arrange. | | | | | Joined: Jun 2011 Posts: 3 New Guy | | New Guy Joined: Jun 2011 Posts: 3 | Just took a 305 v-6 out of a 1963 GMC. 140# compression on all cylinders. Runs Great. Complete motor, carb, clutch, alt, water pump, ect... If any one is interested in it. Scott Moffit Union, Oregon Home 541-562-5134 Cell 541-910-0445 [email protected]
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | The engine inhaled coke by the pound? Yep, it must have been tough!  Jerry
