1 members (Rusty Rod),
105
Mod | | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I'm installing new king pins. The axle is off the truck. I can't remember which is front or back. That's because I sent it off to Nostalgic Sids to have it dropped 4" and I just got it back. The only difference I can see is the little stop bracket at each end to limit the spindle at full turn. Does the little stop bracket go in the front or back? Thanks, john. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy steppenwood, the steering stops mount on the rear side of the axle, hope that helps. | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Thanks, that's what I was thinkin'. Now it's confirmed. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey John, when they drop the axle 4" what does that do to the tread? You have to loose at least a couple of inches in the gooseneck on each side.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Also I think your front springs are closer at the front than the back, and the u-bolt holes in the axle accommodate that. at least that's the case on an AD truck, it's very clear which is the front. | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Denny, the axle still has the same width from king pin to king pin. I talked to him on the phone and ask him how he does it. He said once you get it hot enough, it stretches like taffy. He did a great job. The site is www.droppedaxles.com | | |
