2 members (fonz8261, RLB), 84 guests, and 2 robots.
Topics128,026
Posts1,055,400
Members48,422
#762263 07/14/2011 1:36 AM
I'm installing new king pins. The axle is off the truck. I can't remember which is front or back. That's because I sent it off to Nostalgic Sids to have it dropped 4" and I just got it back.
The only difference I can see is the little stop bracket at each end to limit the spindle at full turn. Does the little stop bracket go in the front or back? Thanks, john.
3B Offline
Hy steppenwood, the steering stops mount on the rear side of the axle, hope that helps.
3B #762334 07/14/2011 4:12 AM
Thanks, that's what I was thinkin'. Now it's confirmed.
Hey John, when they drop the axle 4" what does that do to the tread? You have to loose at least a couple of inches in the gooseneck on each side.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Also I think your front springs are closer at the front than the back, and the u-bolt holes in the axle accommodate that. at least that's the case on an AD truck, it's very clear which is the front.
1952 Chevrolet 3800 pickup
---All pictures---
Denny, the axle still has the same width from king pin to king pin. I talked to him on the phone and ask him how he does it. He said once you get it hot enough, it stretches like taffy. He did a great job. The site is www.droppedaxles.com
