4 members (Otto Skorzeny, Gdads51, Opelika Tom, crenwelge), 75 guests, and 1 robot.
Topics128,062
Posts1,055,851
Members48,428
#762272 07/14/2011 2:13 AM
O K I am sure there is a very simple answer but I removed the radiator fan off the front of the engine to paint the fan and I am not sure if there is a wrong way to reattach the fan to the motor to get the correct air flow off the fan to cool the radiator. I do not want to remount the fan wrong in which case
it may cause the radiator not to function correctly. Hope this makes sense?
cvett #762280 07/14/2011 2:38 AM
Redryder pix
My Hotrod
joker #762356 07/14/2011 11:00 AM
The rivet heads face out toward the front or radiator also the leading edge of the blade as it rotates clockwise is the rounded edge.
Front:
http://www.pbase.com/dennygraham/image/136409663/large
Back:
http://www.pbase.com/dennygraham/image/136409698/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks Joker and Denny.
It was what I thought but wanted to be 100% sure.
