0 members (),
140
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | I would like to remove the cap on top of the shifter where the arms goes into. I have a lot of play here and believe this is the source of much shifting problems, All the other bushing and linkage is ok. Lot of play here though. Look like a pin or rivet holding the top cap on. Any Ideas here? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You should state what truck you are working on. If it's an AD or TF truck the top of the box is held on with screws. There is a cap in the top that will pry off. You can't see much through that hole though. | | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | thanks - Forgot as I had just typed about the pinion bearing and forgot I was on new post. I have a 56 3200 and the cap I am refereing to is the one on top of the column behind the steering wheel. There are two screws into the column and a cap where the shift arm comes in. This is where the play is. Cap appears to have a rivet ??? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | that's the shifter knuckle, and the "rivet" is actually 2 short pins held by an odd spring - these pieces - depress both ends of the "rivet" and the cap pulls off to allow the shift lever to pull out Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | What Bill said. The springs are prone to break after 50 or so years of shifting. | | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | Bill come thru again. Thanks Bill - I will try that tomorrow. The pictures are very helpful. Tom | | |
