7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible), 82 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
#76213 04/11/2007 4:57 AM
I've asked about cleaning my rocker arms here before, but now that I've done that and I have the new 9/16" freeze plugs, what's the best way to install them? They are a very tight fit do I use something and punch them in from the center or try to use the outer rim to punch them in. They look like a bowl and fit about 1/4" down the shaft. I have a 51 GMC 1/2 ton with a 228 engine. The rocker shaft is one piece. Any suggestions.
#76214 04/11/2007 12:22 PM
I have used a deep socket that will fit inside the plug as a driver before. I really think either way you mention should work. Doug
