2 members (Gray_Ghost, Joe W),
211
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 18 New Guy | | New Guy Joined: Jan 2008 Posts: 18 | I bought some time ago a pos. 6v alternator for our firetruck and a du plug and are finally at the stage where we are installing it. My question is this, do I need to reverse the diode in the plug for it to work correctly? The alt. was bought at Carters and I have yet to recieve an answer from them. Please help.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy fireman290, if the "DA" plug is designed for a negative ground system, then yes you would have to reverse the diode leads to work on a positive ground system. | | |
