0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#761768 07/12/2011 5:14 PM
Just trying to see if I get my pictures up. What I am looking for is if anyone knows about this heater. Not sure if I should try to fix it or go electric. I really like the looks of this hot water heater. Not sure where it taps into. Thanks
first48 #761781 07/12/2011 5:50 PM
I do not have illustrations of 1948 GM Chevrolet truck heaters, but here are illustrations of 1947 truck heaters & 1949-1952 truck heaters.
tclederman #761782 07/12/2011 6:06 PM
Thanks tclederman. It looks like the hot water heater that they just had bolted to the firewall might not be the original heater.
Did they used hot water in any of the trucks or would this be something that would have been out of a car.
first48 #761785 07/12/2011 6:24 PM
first48 - all the heaters use the engine coolant for heat source, none electric [except for the fan], and they bolted to the firewall under the dash .... if you can get a pic up someone could likely ID what you have
squeeze #762080 07/13/2011 3:03 PM
I told my wife about my dumb question= That is what you get when you ask before thinking. Thanks and if I figure out how to get the picture from photobucket to here I will be all set.
One other question I have is with a 235 engine with standard 4 speed and original rear end what am I looking at for cruising speed?
first48 #762084 07/13/2011 3:11 PM
linking pics is easy - go to the album with your pic, right click and copy the address from the address bar, come back and paste it in a post here .... although faster is possible, 'safe' cruising with the 3.90 or 4.10 rear gears will be 50-55, remember you might need to stop quick wink
squeeze #762127 07/13/2011 5:18 PM
Leo Offline
Moderator
Moderator
Hey first48, heaters were optional and some people put non-correct heaters in after suffering through one or more cold winters. My heater is actually from a car, even though it works, the PO had to hack two holes through the firewall for the hoses.
Leo #763943 07/20/2011 3:04 AM
Here a picture of my heater. Trying to find out the year and any other information. Thttp://s1233.photobucket.com/albums/ff381/rodger481/hanks
first48 #763947 07/20/2011 3:16 AM
"page not found" .... no 'T' at the beginning of a web address, but doesn't work even without .... just go copy the address of the pic from below the pic where it says "direct link" and paste it in a reply here
I found it, here: http://i1233.photobucket.com/albums/ff381/rodger481/009.jpg
looks similar to the heater I had in a 46 GMC
squeeze #764844 07/23/2011 2:26 PM
That is identical to the one I pulled out of my '53 GMC. It never worked very good and started leaking so I pulled it out. When I turned it around I noticed the letters F-O-R-D on the back! No wonder it never worked very good smile
