| | | Forums66 Topics128,274 Posts1,058,425 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | I once read a post about using a transmission filter as an oil filter on a 261 engine. A bracket was made to mount is on the frame or block. I have tried the search with no luck. Can any one help me? I remember seeing photos too. | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Why? There are suitable engine oil filters available, either bypass or full flow, depending on the year of the engine. Trying to make something fit that's not engineered for the job seems like a big waste of time and effort. Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | you could use an oil filter housing with a nice spin on oil filter, that is easy to find, cheap, and easy to install. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | K9sicem,
Do you have the original full-flow canister oil-filtration system that was originally used on 1959 261 engines (your old posts indicate that you have a 1959 261)?
| | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | This is a new project. 1954 3/4 ton with a 235. It has the original filter but I have a dual cab set up and I want a smaller filter. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The setups you've seen with a remotely mounted spin-on filter are more than likely on engines that have had the oil gallery flow modified. This process is outlined in the Stovebolt "Engine Mod" technical tips and is done when the block is totally disassembled and being rebuilt. It's not a driveway modification.
The stock can filter is plumbed into the 235 block with 1/8" rubber lines that are fed from the block. In contrast, the full-flow filtering system uses 3/8"-1/2" ID lines to handle the increased volume of oil. An unmodified cartridge system would loose excessive oil pressure if a line in excess of 1/8" were plumbed in....that's ,in addition to the 4-6 pounds already lost to push the oil through the can filter.
If you want to see a remote filter mount I have plenty of pictures in my webshots Chevy albums. This modification gives me 45psi at 55 mph at 180 degrees with 30w zppd supplimented oil. Idle oil pressure is 20 psi at normal operating temp and I would highly recommend getting your machinist to make the internal modifications with a rebuild. The machine work and block cleansing set me back $65.00.......cheap insurance!!!
Dave | | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | The engine has already been rebuilt. It has the stock filter. The engine has a dual cab set up and the large oil filter looks out of place and it's hard to find a place to mount. I'm looking for other options. | | |
